Forum Index : Microcontroller and PC projects : HDMI WEB question
| crazycloud Regular Member Joined: 20/08/2023 Location: United StatesPosts: 43 |
When I install HDMIWEB, my pico 2350 does not show up as a HID device in Terraterm. i have tried several pico 2350s, several usb cables. How do you talk to the pico over USB? I have tried the last 2 betas of HDMI WEB, no luck. I must be missing something. |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12034 |
HDMIWEB uses the USB in host mode. You need a USB/UART connected to GP8/GP9 for the serial console |
thank you for the quick response. I will try that with a usb debug cable. |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9220 |
You will need to set Tera Term to 115200 baud. That isn't normally the default. Mick Zilog Inside! nascom.info for Nascom & Gemini |
Thank you. It works like a champ. Mode 2 color and wifi. Awesome! |
